Set up screen and sound lag
G
Glen Fricker
Hi everyone. I'm new to this site, and I am looking for some help. I have an LG 47lb50 TV, and have it running through a Motorola VIP1216 box from my service provider, and I have just picked up a Samsung HT E550 entertainment system. I have the Motorola box and the entertainment system connected via an optic cable, and the entertainment system and the TV connected via an HDMI cable. My problem is when I first hooked everything up, I had my on screen display. I picked up the optic cable, and now I don't have my display screen. How do I get the display screen back?
There is also a slight lag between the sound from the TV to the system. How do I go about fixing this?
I hope I have given enough information to get some help, and thanks in advance.
G
Grador
In the setup menues of your soundsystem there is a setting called "Audio Sync" that allows you to set a delay on the audio.
As for your "display screen" I don't quite understand what you mean. What screen are you referring to?
G
Glen Fricker
I am unable to get the set up, or menu screens to show up.
G
Glen Fricker
I'm probably just missing something, but I can't find the main menu screen for my entertainment system. What am I missing?
G
Grador
Are you forgetting to switch to the HDMI input for the entertainment center vs the cable box on your tv?
G
Glen Fricker
When I switch my tv input, it shows no signal. I think the hdmi cable is good.
G
Grador
If you can't get the on screen display up while there's a dvd playing i'm stumped.
G
Glen Fricker
I disconnected everything, and started fresh. My HDMI cable was bad. Everything working now. Thanks for your help!
