You should really use a larger gauge normal speaker wire for that. First off, CAT5 has small gauge internal wires, too small for speakers really. Secondly, you're making a 100 foot run. You should be running a 12GA speaker cable MINIMUM. If there is a chance that you can run more cable, I would suggest getting some 10 or 12GA cable to run.
