Shadow_Ferret said:
Digital clips music by it's very nature. It's on or off. 1s or 0s. I believe you lose things like decay and in your case, full-out distortion.
My theory is that this is because of the 1s and 0s. Some of the peaks that are part of distortion are clipped off in digital recordings.
This makes sense if you think that music is analog anyway. Vibrating strings and such are by nature analog.
No offense, but each of those beliefs are pure audiophile nonsense spouted by people who don't understand anything about digital audio. Digital audio is not 'on' and 'off' and there is no reason that all digital audio is inherently clipped.
ALL sound is analog. Our ears are analog. Even sounds recorded 'digitally' start out analog - they are captured by a microphone, which is analog, but immediately converted to digital by an a-d converter and saved digitally. As opposed to saving to an analog medium such as tape first and then sampling from the tape which would be the case for older recordings that were originally recorded onto an analog medium.
Digital audio simply samples the analog waveform thousands of times per second and represents the amplitude of the signal at each point in time with a number. Those numbers are groups of 1's and 0's (how many is the 'bit depth' - 16 bits for CD), but we do not hear 1's and 0's. The 1's and 0's are read off the disc and converted back to analog by a d-a converter (dac). Even the cheapest adc's and dacs do a fine job of accurately reproducing the original analog waveform.
When Geezer Butler plays his guitar into distortion and the signal is recorded to an analog medium, the tape will saturate; ie it is pushed slightly beyond its limits but does not break. This is known as 'soft clipping' and as Francious70 points out, it is a characteristic of tape and tube type amps. Some people prefer that type of sound over 'hard clipping' that occurs with digital, but that does not mean that digital is inherently bad. It means that the recording engineer is an idiot and set the record levels too high and/or post-processed the audio with excessive compression or limiting such that a large majority of the waveform is clipped. So blame the recording engineer, not digital audio itself.
With digital audio, clipping is defined as N consecutive samples at maximum level (0dB). N varies - conservative software uses N=4. For CD, 4/44,100 seconds of clipping = .9ms and is entirely inaudible. Now much of today's music is way over-compressed and there may be thousands of clipped samples. A few periods of clipping will be inaudible, but those recordings with thousands of clipped peaks can and will sound harsh. Again, blame the recording/mastering engineer, not digital audio itself.
Digital audio mastered by a competent engineer with very few clipped peaks and sane average power levels sounds phenomenal.
