Guys, I would like to request that you do a Power Conditioner (PC) review with detailed measurements to confirm performance. With advanced PC prices getting up there, I am interested to know if they perform as claimed.
Specific things I would like to see...
- Noise filtering measurements e.g. how do they handle a coffee grinder ( or any other motor device) plugged into the same supply circuit? Also how good is isolation between output circuits/banks.
- High voltage/lightning protection. Are they any better, both clamp voltage and repeatability, than your average surge protector strip? Perhaps you can use a stun gun as the source.
- Voltage regulation. Is it truly a regulation circuit or just basic switch that taps several transformer windings based on the input voltage?
- Load performance. I have two XPA amps which Emotive recommends to not connect to a PC (mine are not installed yet). Does the average PC limit available current to high power electronics?
- Front panel meters. Are they accurate? Do they actually measure the true voltages and currents, or are they just an approximation?
- Do overvoltage and undervoltage circuits work as promised, triggering on accurate thresholds? Are they user settable? With a projector (and no UPS) would you be better served trying to clamp the voltage rather than shut down the power and risk reducing bulb life?
Maybe some of my requested tests are extreme but it seems there is little to no tangible measurements on the performance of these products. Given the extraordinary amount of time devoted to electrically testing passive speaker cables, the fact that a bad PC could easily have a more negative effect your system's performance, and that pricing for these devices can often outweigh speaker/interconnect cables, is it time for a more thorough review?
Will AH take the lead?
