I bought the Boston Acoustics MCS 160 new several months ago and have been impressed with it's performance, unfortunatly I cracked the speaker on the subwoofer during a move. So now I'm looking into replacing just the speaker and found the Boston Acoustics G108 online which seems to fit the MCS160 subwoofer speaker hole alignment
http://www.bostonacoustics.com/US/Product/Pages/ProductDetail.aspx?PCatId=CarAudio(BostonAcoustics_US)&CatId=SubwoofersCar(BostonAcoustics_US)&SubCatId=G1(BostonAcoustics_US)&Pid=G108(BostonAcoustics)
http://ca.denon.com/DocumentMaster/US/DHT1312BA_MCS160_Owners_Manual.pdf
However I have a couple of concerns:
1) the MCS160 subwoofer is rated at 100 watts RMS and the replacement G108 is rated at 200 watts RMS. Should I be concerned that the circuitry of MCS160 subwoofer will be strong enough to push the 200 watt G108 enough that it will handle as well or better than the OEM MCS160 subwoofer?
2) the impeadance of the MCS160 subwoofer isn't listed in the owners manual so I was wonder if I should be concerned with the 4 ohm replacement?
Thanks
