Remote Sensor Not Working On Pioneer Plasma Model PDP-42A3HD
I
iKokomo
Ok, so I have had a Pioneer Plasma Model PDP-42A3HD for a bit and the TV itself it works great and looks amazing.
My problem is the remote sensor on the TV does not seem to work.
The reason I say remote sensor is when I hold up the remote to a camera, you can see the IR blinking purple, so I know the remote is working.
Why does this happen? Is it a setting on the TV that got messed up, maybe a reset?
Other than that slight problem, it works amazing!
What kind of lighting do you have? If they're reflecting into the IR window, it won't work well, if at all. When did this start?
I
iKokomo
Tried that, I even held it up to the sensor right next to it and still no go.
