I've decided to spend around 80% of my budget on speakers, or around $2000. (I'm going to spend the other $500 on a refurbed Denon 2113CI from a4l.) The room is kind of an open space, but the viewing / listening area is about 12X14. The sofa will be about 2 feet from the rear wall.
I've basically decided on the following speakers:
- PSB Image T6 x2 (b-stock)
- PSB Image C5 (b-stock)
- HSU STF-2
Welcome to the forum and good call on the budget! And the T6 is a very good measuring speaker (that I have not personally heard).
IMO, get the Denon 3312 new open box from Amazon for
$565. Looking at the
measurements in the Stereophile review of the T6, they are power hungry beasts
and the 3312 amp section is much better than the 2113. The features in the 3312 are marginally better too, so, win win.
The surrounds don't add that much (my subjective assessment) to the soundtrack and since very few movies truly push the envelope with those channels, you can leave them out completely, for now
. Even then, since you are 2ft. to the back wall, you'll be getting a lot of front sounds reflected from that wall (look into acoustical treatments for the side and back walls). It is recommended, for best possible room acoustics, to have the listening position be 38% from the front or back wall. Further, because of your proximity to the back wall, there is not going to be enough room to properly place the rear surrounds, unless you can move the couch about 5-6ft away from the back wall (which just happens to be in the 38% territory for the 14ft length). Another thing to remember is that the surrounds don't need to be from the same brand/series the fronts as long as they can keep up.
On the subject of sub, IMO, don't skimp here. Don't go lower than the
VTF-2 MK2. If you must, run 2.0 for now and build up the sub budget?
IMHO, your speaker acquisition path should be, T6, VTF2, second VTF2, surrounds, C5.
