So my family room has limited space which requires me to have my sofa against the wall and this will not be changed per the wife. Also with being open to the kitchen i have no wall on the left side of the room to do surround on the side walls. So that leaves me with in wall behind the sofa. A few questions.
1. How important is it that the rear surrounds match the fronts, if same brands isn't that important what about size should i try and keep them the same general speaker size as the fronts?
2. Height and width of placement, so 3 feet above the seated position is what i've read but how wide out equal to the front left and right or is wider better?
3. Dipole, bipole, regular speakers, i'm lost with this what will work best for my limited placement?
4. Would in ceiling work better than in wall, much harder to install for me but if it would be alot better i would figure out a way to make it happen.
Thanks for the help..
