Whew! 6,5 dB better than an "ordinary" dipole (whatever that might mean)? And it is still just a dipole (no parasitc elements)??
But this thread is not about criticising types, so .....
Just to add that close to earth or inside a building, classic antenna characteristics and polarization is influenced by the surroundings, people walking, etc. ("Close to earth" for FM means any substantial object closer than a wavelength, or about 3m.)
Thus as said there may not be large advantages obtained from special antennas practical for room use. Buckle-meister, you may try getting that antenna shorter. I presume your FM is also 88 - 108 MHz, where the "ideal" single wire length would be about 80 cm (31 inches), i.e. a quarter-wave long. Only remember if you experiment, you cannot hold it by the end; that is very high impedance and you will change matters. Sounds funny, but tape the end to an insulated rod (your broom-stick!), and then move it around. But if you already have good reception, chances are you will not get much improvement. Does your receiver have a signal strength indicator? With FM it is not easy to hear small improvements.
