Rack idears please help
Discussion in 'DIY Corner - Tips & Techniques' started by Bryceo, Dec 7, 2012.
  1. Bryceo Banned
    Bryceo
    May 13, 2012
    2,175
    422
    Victoria wangaratta Australia
    Need idears want to do a corner mount rack
  2. Gordonj Full Audioholic
    Gordonj
    Apr 28, 2012
    256
    53
    Va
    Are you looking for a nice piece of furniture to sit in the corner with your gear inside? Or a true floor or wall mount rack for the corner? Either could be kinda tuff. Maybe try Middle Atlantic
    Middle Atlantic Products
    You can also look at their sliding cabinet product that you put the assembly in your own credenza. So, as long as it meets the space requirements you can insert the rail system and the equipment then slides in and out of the rack. It is great for custom installs and wiring.
    Middle Atlantic Power Products - REB Series Rotating Sliding Base
    Also keep in mind that you might need to consider cooling for the rack if it is a credenza, Middle Atlantic also has great new product for that problem as well.
    Middle Atlantic Power Products - Power and Lighting Index
    I hope that helps some...
    Gordon
  3. connieflyer Audioholic
    connieflyer
    May 15, 2012
    102
    36
  4. 96cobra10101 Senior Audioholic
    96cobra10101
    Sep 13, 2010
    663
    158
    You should probably list what your going to have occupying the rack to the post. A Bluray player or lower series receiver will probably be fine in most racks and not be a weight issue. But power and weight seem to be relative in the audio world. I for one would not trust glass shelves with my XPA-5 or my AVR-4810, those 2 items alone weigh north of 100lbs.
  5. agarwalro Audioholic Ninja
    agarwalro
    Jan 31, 2005
    3,973
    1,033
    Pittsburgh, PA
  6. Bryceo Banned
    Bryceo
    May 13, 2012
    2,175
    422
    Nice corner unit for my gear to go inside
Share This Page
  • CEDIA
