Im used to using regular banana plugs, but just recently, i purchased 2 additional speakers and wall mounts (which are already mounted).
because of the wall mount design, i am unable to use banana plugs, they are in the way.
so i purchased the monster QuickLock MKII Gold Flex Pin.
once the wire is connected and i screw it closed. how does the flex pin connect to the speaker?
does the flex pin go in as it would like a banana plug? or does it wrap around the base of the binding post?
