Its been a while since I've done anything with my system so be kind!!
I recently coverted to a Harmon-Kardon AVR-345, driving an old pair of DCM Time Windows speakers, very happy with them.
With my old system, before it died, I was using a DCM VLS-2, which was a powered subwoofer and an additional speaker module for voice/Mids. It was supposed to be used with just a TV input, to provide better audio, etc. It also had an amplified input option, which is how I had it hooked up to my old system. The subwoofer was all I was really using it for.
Now to my question. As the VLS-2 is dead, no power lights/output, what is the potential to hook the sub-out from the HK-354 directly to the subwoofer in the VSL-2 cabinet? Does the HK provide the cross-over/filtering to drive a subwoofer as is, do I need to worry about impeadence matching or any other potential issues with a direct hook-up? Of course I would remove the power supply/amp module from the cabinet and just connect the HK directly to the subwoofer.
Any guidence is greatly appreciated, just trying to re-use existing equipment, hate to trash something it still has use.
Thanks
