The high end receivers cost too much and I feel it's a waste for not to use the built in amp.
If I was buying such a rig, I would split the difference. Get the SR7005 (Damn, that is a nice looking receiver
), and buy an Emotive XPA-3 for the mains and center.
AVR's do not have the best power reserves and this will likely be an issue if you listen
loud in a
large room with speakers which are
not efficient and/or have
complex demands.
If you have content which has loud signals on all 7 channels at the same time, the SR7005's power reserves can be topped out.
Look at the spec. for the SR7005:
Power Output (8 Ohm) 125W (20Hz - 20kHz, 0.08% THD, 2ch driven) x7
What the heck does that mean?
If the specs in parentheses are for 2 channel, then under what conditions does it provide 125Watts to all 7 channels? Can it provide 125 watts to all 7 channels at the same time? How much headroom or capacitance does it have for a sudden demand?
If they don't call out a spec for 4 ohms, it is most likely because it would be a point of embarrassment.
Now look at the specs for a dedicated amp (I chose Emotiva's UPA-7 because it is also 125W):
Power output (all channels driven):
185 watts RMS @ 4 ohm (0.1% THD)
125 watts RMS @ 8 ohm (0.1% THD)
Transformer Size: 850VA
Secondary Capacitance: 90,000uF
Emotiva goes on to provide links to the actual test data from the third party lab they use.
In loose terms, RMS means it can comfortably sustain this power level.
I don't know much about how to interpret the transformer and capacitance spec., bit those that do say this gives the amp outstanding ability to meet a short term spike in the signal which equates it to
much more than the 125 watts of a AVR.
So, as AVR's go, the SR7005 amp section is pretty strong, but it is definitely not equivalent to a properly designed separate amp. It is "no brainer" that the SR7005 amp section is wholly competent at driving the 4 back speakers alone.
Thus use the receiver as pre/pro and rear channel amp and use an XPA-3 or similar for the front channel. Unless you have some extremely demanding speakers, the UPA would do the job just fine, but if you are spending $1500 for a pre/receiver, it just seems like the XPA would be a better fit.
