My speakers are the EMP Impression series for all fronts, center, and rear. The fronts are "large" speakers in a sense, they each have 2 6.5" woofers, 1 5.25" mid, and a 1" tweeter; even before my sub I thought they sounded pretty good. But see, setting the fronts to large means that LFE that would normally be sent to the subwoofer for the front channels, won't.. unless I set my sub to "Plus" rather than just "Yes" in the manual speaker setup, sending frequencies below the crossover setting to both fronts and sub. Then I run into too much bass..
My sub is Elemental Design's A3-300, and they recommend using a crossover setting of 50-60 hz.. So, you see the delemmas here.
