One other thing. Putting floor speakers & towers on a pallet for shipping is the best way to go. I was considering asking the seller to do this and I know this would have turned out much better. Freight shipping can be a pain on the other hand but if I ever consider buying anything this heavy/expensive again, I will probably require it.
Post just a few times, some jibberish, here to get post count up.
http://forums.audioholics.com/forums/showthread.php?t=49318
Freight is no guarantee either, as you can see with my last visit to the freight center to pick up my subwoofer kit. It was luckily fine, but it looks like a forklift ran straight into it.
I have had damaged goods from every carrier, but unlike most people, I get fewer incidents per packages received with UPS. I have worse luck with FedEx, but no, none of them are very reliable.
As for the "3rd" wheel of a speaker tower, it's funny because I have been precisely looking for one for a new center speaker, for my future AT screen setup. If you have a smaller flat panel, consider doing the same, by keeping the good tower, and adding another pair. If you have a PJ setup, consider AT. Seymour DIY fabric is very, very affordable.
Yes it will look funny to some, and many people will ask you when they visit, but it is undoubtedly absolutely the best setup you can actually do. Best acoustical match, typically better power handling, typically better horiz dispersion, typically better dialogue intelligibility, and typically better panning with even height of drivers.
You'll probably think I'm crazy, but I actually willingly bought a pair, with one speaker being decimated. Well, I guess I'm not crazy because I just wanted one more tower, and this purchase saves me some coin. I'm in the middle of a project in fixing it up. Here's the thread:
http://forums.audioholics.com/forums/showthread.php?t=68668
