Hello all! This is my first post on this forum and I'm an audio newbie so please bear with me if I ask the wrong questions or use the wrong terminology. I'm here to learn! I didn't get any responses over in the headphones section and I know it's bad to re-post, but i'm trying to get some advice before Christmas so have a little Christmas spirit and help me out!
I'm looking to buy a pair of over ear headphones between $100-$120. I purchased the Beats by Dre. Studios 4 years ago but they have fallen apart and I've been told on many different occasions that there are better headphones out there for less.
Let me describe my current audio habits. I primarily listen to music through my PC. I'm not using a soundcard: it's just the on-board audio chip. My music library isn't chocked full of high quality files (mostly Electronic). I game on my PC a lot; but not competitively or in any specific genre. I plan on buying a mic later down the road but it's not necessary right now. I don't need noise canceling (though it is nice) or any sort of bass boosting. My biggest complaint about my Beats is that they are pretty uncomfortable after a couple of hours.
The only other headphone company that I've heard of is Seinheiser, so any discussion or feedback is welcome.
Thanks in advance!
The first thing I will give is the link to HeadRoom. They do not always have the best prices, but they are a wonderful resource.
HeadRoom: Headphones: Full-Size, In-Ear, Wireless, Noise Cancelling, Headsets
Do you want closed back or open back headphones?
A few years ago, I got the closed back Sennheiser HD 280 Pro, which has very good sound isolation, but fit pretty tightly, though it was never a problem for me. It is easy to drive and our computer soundcards work fine with it. The sound is pretty good, very clear on voice, but not as warm, smooth, and spacious as some others. Later, I got the open backed Senn HD 598, which is warmer, smoother, and more spacious.
Based on the measurements at HeadRoom, plus their comments, these might be good bets in your price range.
For closed back, the Sennheiser HD 449 might be a good bet. HeadRoom thinks they will work very well from a computer soundcard, too.
For open back, the Sennheiser HD 518 might be a good bet. These use similar technology to my more expensive Senn HD 598. The measurements indicate they would be little warmer in
sound. HeadRoom thinks they are easy to drive, and should work well from a computer soundcard.
