<font color='#000000'>Hi
Welcome to the forum
You are not going to get good bass from a speaker that needs to be mounted up high ender the eaves of your home
they will disperse well but not have great lowend response
If you are looking for good low end response try a pair of TIC Outdoor Rock Speakers hidden in your landscaping
TF-11CN
175 watts, 47Hz-25Khz 8" co-axial driver with titainum tweeter,Buitin transformer
They look like rocks and your guests will not know were your spakers are located If you want to get crazy there is also
a 8" matching subwoofer available
TF-50CN
250 watts 8: woofer
If you dont care about concealment
you can use the TIC GS-6 Exterior In-Gound speakers
and GS-50 Subwoofer
Hope this helps</font>
