Hi All,
I sent this e-mail to Oppo support, and wanted to know if any of you might be having the same problem with audio dropouts and freezing.
"Hello,
Since having my Oppo player in March of this year, I have had problems of video playback doing a split-second jitter during a movie followed by a complete loss of the audio track. The video will keep playing, but the audio track is absent. I have updated the firmware approximately three times since March and have still had problems with it. Back in March, my setup was Oppo BDP-93 via HDMI to my Marantz SR6003 via HDMI to my Sanyo TV. I have tried switching out the cheap HDMI cables with Blue Jeans Cables, and I have also since replaced my cheap Sanyo HD TV with a Panasonic HD TV (not
because of this, just wanted to upgrade). Still no changes in the audio dropout problem I get.
It seems to happen most with DVDs, and then less frequently with Netflix streaming, and no problems whatsoever when playing a Blu-Ray. I understand that I can have the video going out directly to the TV via HDMI 1 on the Oppo and the audio going out via HDMI 2, but frankly I shouldn't have to do that. The whole point of routing everything through my Marantz is that I only have to switch inputs on the Marantz, not on both the Marantz and my TV anytime I want to switch between different devices. Either way, that is a workaround to the problem rather than fixing the problem. It could possibly be a problem with the Marantz, but I'm not sure.
What will fix the audio dropout problem is if I switch inputs on the Marantz from "DVD" (I have the Oppo connected to the DVD input on the Marantz) to some other input on the Marantz (like say TV), and then back to the Marantz's DVD input. Then the audio track is restored. The only reason why I suspect this is an Oppo player problem and not a Marantz receiver problem is because I have had the Oppo player freeze up on me numerous times. Any help would be appreciated."
I like the fact that this unit plays both Blu-Ray and SACD, but other than that my old, non-HDMI Pioneer DVD player was a lot better in terms of reliability and ease of use.
