I see. So when you were talking about switching, you were referring to going in to change setttings for HT to stereo?
Also what are your feelings on sound quality in stereo. Do you find the sound sterile or grainy compared to other setups you have used?
I am not trying to avoid your question but sound quality is so subjective there is just no way to answer properly.
Personally, I am a fan of accuracy and transparency. Many years ago, I bought Revel Salons because I refused to spend that kind of money on a speaker that was not accurate and full range. I still have them, but they now perform up to their potential.
As a software person, I used to believe that if it were digital it had to be better because there was less opportunity for error.
At one point, I had modded an Auzuntech soundcard and it sounded great, but still I believed there had to some equalization responsible for this. My HDMI BD player, although it sounded worse must be correct and I stuck with it.
Then, Oppo sent me a BDP-95 to beta test and suddenly the sound I heard from the Auzuntech had returned.
Many CD's that I had written off were not that bad.
So, I have developed an opinion that LPCM bit streams are not always, in and of themselves, a guarantee of good sound quality. There can be problems when processing a digital data stream that can reduce sound quality. This is easily proven by altering the bit-depth and bit-rate when streaming to USB DACs. The data is the same, yet the sound can be altered. For, me this was a Q.E.D. moment.
I have limited experience with other products, the BDP-105D is a great product, but for a two channel system where bass management is not required, I prefer the HA-1. So, I have both with the HA-1 in HT bypass for 2-channel.
Neither product is what I would call Sterile or lacking in transparency.
If you need the streaming feature of the BDP-105(D) or bass-management this is a great choice.
I do not need these features for two channel and want the most accurate transparent product, so the HA-1 is my choice.
However, that may not be a better choice for your system.
My brother-in-law put together a system with a BDP-105, Revel F206's, and Grotti sub and he absolutely loves it, so do I.</SPAN>
As far as Audyssey is concerned, I am of the opinion, that there is a cost and a benefit. In my system, in my room, the cost outweighed the benefit.</SPAN>
- Rich</SPAN>
