On par with Monoprice?
Martiad3
Seeing as how monoprice is completely sold out of all of its speaker wire, does anyone know where I can find some 14ga speaker wire at around the same price?
I've looked at radio shack and other places, and they're all 16ga and smaller or really expensive. Am I SOL and need to wait for monoprice to get in stock, or does someone know where I can find some wire?
agarwalro
agarwalro
Ebay it. You should be able to get the same or comparable wire.
jaxvon
jaxvon
Martiad3 said:
Yes I did. Unfortunately their 14ga wire is 5x the price per foot of the monoprice wire.
You should check your local Home Depot. They often have decent prices on 14ga speaker wire.
At Home Depot, as was suggested, you should also check out the low voltage landscape wires. They are usually less expensive.:D
