KEW
Paradigm Studio20 vs RBH 61-lse
Well the RBH's I bought through Audiogon showed up so I pitted them against the Paradigm's. The Totem shop is closed for vacation this week - so that is next weekend.
First, I should point out that the RBH 61-lse was only available for a limited period and was discontinued something like 6 years ago. The closest model currently available is the 61-SE/R.
Second, I should state that I brought the Studio 20's home. The dealer offered me a pretty good discount, so I won't get too beat up if I sell them. This allows me to do the audition in my home and at my leisure and to carry the Studio's to other shops.
I spent quite a bit of time getting the sound levels equal with the Radio Shack analog meter. I set the meter to C weighted and fast response. I did this by playing a passage with a sustained note (I would guess close to middle C) at the start of a cd track repeatedly while switching between speakers until I had them balanced.
I spent a total of 4 hours on this audition (I was enjoying hearing my favorite music on these two speakers)!
My findings for these speakers relative to each other are:
Paradigm pros:
1) The highs of a cymbal or triangle had more presence - I interpret this as the very highest frequencies staying strong on the Paradigm while rolling off a touch on the RBH. I spent several years playing in jazz bands and pit orchestras (for musicals) and I don't feel the Paradigm's highs are exaggerated.
2) I have thus far ignored lower bass because I intend to use these speakers in a 2.1 system. However, with these two speakers, the extra depth of the Paradigm kept attracting my attention. I think this is because both speakers sound very good in so many respects that the bass difference simply becomes the most pronounced distinction. The bass seemed to be accurate on both, but the Paradigm did a better job of catching the note of a tympani. The RBH was okay on the hit, but didn't capture the resonating note nearly so well.
3) Fullness and warmth - there were places where the Paradigm sounded richer and fuller and the RBH seemed a little bit thin. Some of this could be from the fuller bass.
RBH pros:
1) Wide sound stage - these are the first speakers I have heard which distinctly placed a voice farther to the sides than either speaker was located! I'm not sure this is a good thing, but it impressed me. In contrast, the Paradigm seemed to crowd all voices in between the speakers.
2) Clarity - while the Paradigm produced the highest frequencies of a cymbal tap with excellent presence, the RBH compensated with a truly outstanding rendition of the balanced harmonics of a cymbal.
3) Openness - I guess this is partly a rehash of #1, but with the voices spread out, the music was simply less crowded. Voices were more distinct, and it seemed like the music was quieter in between notes, if that makes any sense. Although I give the Paradigm some credit for fullness and warmth, I liked this openness more.
The Acid Test - Since I had these at home, I called my 11 year old daughter into the room to utilize her young ears and see what she said (she enjoys it when I ask her opinion especially on colors and I guess sound is similar). I had Clapton, which she likes, on the RBH's. She walked into the room, sat in my chair and said "okay, switch it". I did and she immediately got up and said "the first ones are better". Crap!
I spent a lot of time just making sure of what I was hearing and that it was consistent across music types, etc and she has no doubts at all after 30 seconds in the room. "Wait, what is it you like about them?". "They are clearer, these sound dull!"
I think it can't be that obvious. She doesn't understand the subtle interactions at play. So I bump the volume on the Paradigm's up 1dB to give them the sound level advantage. (Ha! Old age and treachery beats youth and enthusiasm any day!
) I told her I made some adjustments and call her back in. She doesn't miss a beat. She has no way to know which is which, other than the sound, I switch to the second pair and she immediately says "this one is still clearer". This one is the RBH at a lower volume level than the Paradigm.
There it is - a completely unbiased opinion!
Overall, the RBH's take the prize. I thought they might win - after all, the 61-SE/R which is the modern version with a crossover that is not supposed to be as good as the 61-LSE costs ~$2600. However, I liked the sound of the Paradigm so much that I wasn't expecting the RBH to be this conclusively better.
If I did not plan to have a sub in the room, I would have to give the nod to the Paradigm; it really does put out impressively honest and deep bass for a bookshelf unit. But for a 2.1 system, and to my (and my daughter's) ear, the used RBH is definitely a better way to go.
Cheers,
Kurt
Paradigm pros:
RBH pros:
Cheers,
Kurt
