M markD53 Audiophyte Sep 13, 2007 1 0 0 Sep 13, 2007 #1 Just bought a Onkyo TXSV414Pro and hooked up some bose speakers......Volume is very, very loud and I can't turn it down with either the volume knob or the remote. Appreciate any thoughts or ideas!
ParadigmDawg Audioholic Overlord Nov 20, 2006 10,567 0 113 Hiding from Alex Sep 13, 2007 #2 Never heard that one. Does it have an auto calibration option? If so try that and see if it works but first I would unplug it and then plug it back in. markD53 said: Just bought a Onkyo TXSV414Pro and hooked up some bose speakers......Volume is very, very loud and I can't turn it down with either the volume knob or the remote. Appreciate any thoughts or ideas! Click to expand...
mtrycrafts Seriously, I have no life. Aug 19, 2004 23,550 0 113 Sep 13, 2007 #3 markD53 said: Just bought a Onkyo TXSV414Pro and hooked up some bose speakers......Volume is very, very loud and I can't turn it down with either the volume knob or the remote. Appreciate any thoughts or ideas! Click to expand... Sounds like you have it set up incorrectly or one of the wrong buttons pushed. Does it have a mute button to see if that shuts off the volume? You need to check everything on it, especially if you have the manual for it still. Another though: do you have access to other speakers to try? which Bose speakers do you have hooked up and how? Anything else hooked up?
R rnatalli Audioholic Ninja Jul 2, 2007 4,050 0 113 Sep 13, 2007 #4 I hope you auditioned other speakers in addition to Bose. You might regret it later if you didn't. As for the volume, I've never heard of this happening, but mess around with it and if nothing helps, replace it.
