Newbie Question on Yamaha HT-5960 receiver and decibel levels
Discussion in 'Beginners and Audiophytes' started by BrentS, Nov 18, 2007.
  1. BrentS Audiophyte
    BrentS
    Nov 18, 2007
    2
    0
    So, maybe this is a dumb question, however, I'll give it a shot...
    I installed a Yamaha HTR-5960 Receiver in my Family Room (along with a Sony LCD and Directv HD-DVR). How come my volume levels are showing in negative decibels? Shouldn't 0 dB be absolutely quiet and positive dBs be louder? I routinely watch the TV at -40 dB on my receiver. What gives? Did I set something or configure something incorrectly?
    Thanks for anwering a newbie's question!
  2. Seth=L Audioholic Overlord
    Seth=L
    Sep 26, 2006
    13,446
    2,014
    It reads as relative decibel rating. There is nothing you can do to change it. To be perfectly honest I have never seen an explanation for why they do this (am sure there is a logical reason, I just don't know the answer). You need not worry, as it is designed to read that way. Low end Sony receivers, for example, show Absolute volume where it starts at 0 and works its way up.
    Someone correct me if I got the titles for each volume scale backwards. It is 2:30 A.M. and I haven't had much caffeine to compensate.:)
  3. mtrycrafts Audioholic Slumlord
    Aug 19, 2004
    16,054
    1,354
    It is the way that was established in the industry with 0dB being full scale signal and anything below it is negatively designated. I imagine that in mastering you don't want to get above the full scale, 0 in this case. If it wasn't like this, how would they designate full scale, 100? 80?
    So, it is best at 0 and so everything is likewise in reference to 0 full scale.
  4. MDS Audioholic Spartan
    MDS
    Oct 23, 2004
    6,691
    863
    Austin, TX
    You certainly haven't been paying attention as I've explained it no less than two dozen times. :D
    Yes, the scale with negative numbers is known as the 'relative' scale - as in everything is relative to 0. It has no meaning until you calibrate levels. If you follow the Dolby conventions and calibrate so that 0 is 'reference level' (105 dB peaks) then -10 dB on the display means that you are 10 dB below 'reference'; ie 95 dB peaks.
    The 'absolute' scale (0 - whatever) is no different. It is jut not as convenient for determining at a glance how far away from 'reference' you are.
    On the absolute scale, 0 would be silence. On the relative scale, 0 is reference level and -80 or -infinity( however low it goes) is silence.
    Despite the fact that 0 dB may have some defined voltage level, like 'unity gain', it means absolutely nothing. The volume display could read A-Z and it would be the same (it just wouldn't make sense as we are conditioned to think of volume as a numeric quantity).
    MDS,
  5. BrentS Audiophyte
    BrentS
    Nov 18, 2007
    2
    0
    Thanks guys. So it sounds like (hah, pun intened) that I can't do anything about it and I just live with the negative numbers :)
  6. Seth=L Audioholic Overlord
    Seth=L
    Sep 26, 2006
    13,446
    2,014
    I drift in and out.:)
    Thank you for the information though.:)
  7. mtrycrafts Audioholic Slumlord
    Aug 19, 2004
    16,054
    1,354
    Yep, just live with it as you would if we just converted to the metric system:D
Share This Page
  • CEDIA
