MINT: Jolida JD-1501 RC integrated hybrid
N
nhpm510
Greetings all,
Let me know if you have any interest, considering some revision to the 2 channel set up. Combines the best of two worlds, a tube pre-amp with a solid state power amplifier. A smooth silky sound with pace and bass at an affordable price and the convenience of remote control. Will permit the connection of a powered sub :) Desire to conduct it via Ebay for the Mircosoft Live 25% rebate.
Construction Details and Features:
Fully Integrated Stereo Amplifier: Input 500mV driving 100 watts.
Remote Control: Volume( +/- ), Standby, & Mute
Multiple Inputs: Front mounted push button selector switch-CD, Tape Recorder, Tuner and Aux. (for VCR, DVD Player, TV, Computer) and two tape outputs.
State of the Art Components: ALPS audio potentiometer, gold plated RCA input jacks.
Rated Output Power: 100 W per channel at 8 ohms, 22Hz to 19KHz
Frequency Response: (at 1 watt into 8 ohms) 5Hz to 100KHz + 1dB
Bandwidth: 22Hz to 19kHz + 3dB; 0dB 100 W 1KHz
Distortion THD: Less than 0.1% at 90 W output, 22Hz to 18KHz
Input Impedance: 47Kohms
Input Sensitivity: 500mV at 1KHz and 8 ohms for 100 watt output
Noise and Hum: 90dB below rated output
Tube Complement: 2 pcs. 12AX7 for the preamplifier.
Power Requirements: 110V-120 VAC 60Hz 180 watts-standby, 450 watts maximum (220 VAC 50Hz option).
Dimensions: 17 inches wide by 13 inches deep by 4.5 inches high high.
Weight: 32 pounds net, approximately 35 pounds packaged.
As for feedback, I've trade here long before there was a feed back thread :)
Also, over 30+ at AV123.
Pics later today.
PM
N
nhpm510
Pick-chures :)
Can you say: Jolida? :)
djwilbourn
Have you sold the amp?
Paul,
Wondering if the amp is still for sale? Thanks
David
jhw59
David--still for sale :)
Rgds,
PM
I can't pm due to lack of posts so.....
Might be interested if still for sale. Is there an input for a powered sub or would it go through the aux input?
Also, are you the original owner? Is there any kind of warranty? I assume the tubes are stock? Do you live near Washington DC for pickup?
Thanks
Jay
