I was watching The Police: Certifiable on Blu-ray the other day, and I found that I was disliking the way Sting’s vocals sounded coming from my centre speaker (an Athena C1). Out of curiousity, I set my receiver to phantom centre, and noticed two things immediately:
One, the vocals were so much clearer and sounded less tinny and more powerful. Two, the vocals were noticeably louder than when they were coming out of the centre speaker.
As for the first point, well, maybe the C1 ain’t the greatest centre speaker in the world. I’ve been thinking that I oughtta replace it with something better. Or at least tweak the centre EQ settings in the receiver. Would that actually do the trick, or is getting a better centre the thing to do?
The second point is interesting. I have a non-HDMI receiver, so when it comes to the hi-res audio codecs, I use the multi-channel analog audio outputs. I immediately checked to make sure that all the interconnects weren’t partially hanging out but no, they were in there all snug. Then I grabbed my trusty Radio Shack SPL meter, and did some measurements, using the AIX Blu-ray test disc and its speaker balance tests.
Using my BD player’s multi-channel analog audio output into my receiver, I did my usual bit of balancing all my speakers to 70 dB, the sub to 72.5 dB and the centre to 72.5 dB –- I do that to the centre to compensate for the relatively powerful Athena F2 fronts.
Out of curiousity, I put the receiver into phantom centre mode and found that the phantom centre signal was registering 74.5 dB on the meter. NOT the 72.5 dB I was expecting.
So my question is how should I go about setting the level for the centre when in multi-channel? Keep it at the 72.5 dB that I had before (to keep it in line with traditional leveling methods), or bump it up another 2 dB (to keep it in line with how a phantom centre would sound)?
(Note that when using a digital input with my non-HDMI receiver, the levels were the same for centre and phantom centre. Note also that sticking with a phantom centre is fine with me, but is not the solution for when I watch movies with friends scattered about the room.)
cheers,
supervij
