Hi Guys,
I've been doing research on speakers I can use in a home theater I am building. My initial thought was to go with Klipsch 650 or the Definitive Tech 65. The original discussion is here in this link:
http://forums.audioholics.com/forums/beginners-audiophytes/91719-klipsch-kl-650-vs-definitive-technology-studiomonitor-65-a.html
The Definitive Technology 65 was quickly ruled out.
After a few PM's and doing more research on the forum it looks like a the JTR Triple 8HT and Atlantic Technology 8000e are also very highly rated by users.
They will go a ~7500 cubic foot room. Bass will be supplied by eight 18" infinite baffle subwoofers mounted in a manifold that goes into the attic so the bass will be no problem.
In a room this large the Klipsch 650 may be stretching to get the job done. Further research brings in the Atlantic Technology 8000e or the JTR Triple 8HT. I havn't heard them but the reviews look really good.
Which would you suggest?
Thanks,
Tony
The distance between the speakers and listening position is 21 feet.
Wow Tony! That's a large room with a fairly long listening distance.
In your other thread I recommended the JTR Noesis 228HT and now seeing your listening distance I'd reinforce them as the better choice over the Triple 8HT's. The primary reason is - as good as the Triple 8HT's are (I agree with MidnightSensi2) - their HF compression driver firing coaxially through the 8" midrange has a 90deg X 90deg (conical) dispersion pattern. Because of your long listening distance, this brings reflected sounds off the walls, floor and ceiling (depending on orientation) into play a lot more in what you hear at the LP. OTOH, the advantage of the
Noesis 228HT is that the HF compression driver is mounted on a very good 18sounds controlled directivity horn with a 60deg(H) X 40deg(V) dispersion pattern. This will counteract the effect of your long listening distance because significanty less sound will be sprayed at the room's surfaces, therefore greatly increasing the proportion of direct sound from the speakers in the mix you hear at the LP.
Also, JTR are also
discontinuing the Triple line (superseded by the Noesis) and it appears that the Triple 8HT's are sold out. I'm sure Jeff P (JTR) will build you a set of Triple 8HT's if you really want them, but the runout/sale prices are finished.
Are you still planning on flying the front speakers from the ceiling? I found
this thread yesterday which confirms that Jeff will install threaded inserts and mounting hardware on request.
With a (conservatively rated) 98dB/1W/1m sensitivity, the JTR's can easily be driven to thunderously loud (if you want!) levels with your 4311CI, even at your relatively long listening distance. By comparison the Atlantic Technology (89dB) and Klipsch (92dB) setups, while probably very solid THX Ultra2 rated speakers, will require at least 8 times and 4 times the power respectively to reach a given volume.
Edit: Sorry, I posted before I saw your last post. JTR is internet direct only. The best way to contact Jeff is via the phone number on the website.
