Input Power (Maximum/Nominal)???
Discussion in 'Loudspeakers' started by Deadhorse, Jan 9, 2008.
  1. Deadhorse Enthusiast
    Deadhorse
    Mar 12, 2007
    17
    0
    What exactly does this speaker spec mean?
    Input Power (Maximum/Nominal): 120 Watts/40 Watts
    My receiver is 100 Watts per channel so I assume even at full volume I can not damage the speaker but does it mean that optimal usage is with only 40 Watts input?
  2. 3db Audioholic Overlord
    3db
    Sep 7, 2002
    11,381
    2,736
    Ottawa Canada
    Nominal power is the continious power (long term) a speaker can use without overheating its voice coils. Maximum power is very short term spikes in power that the loudspeaker can use without damage.
    At full power, most receivers clip when driving any kind of load thus damaging your speakers. Rule of thumb is, don't go past the 12 O'clcock position on your receiver and you'll be safe.
    3db,
  3. rufas2000 Junior Audioholic
    rufas2000
    Oct 30, 2006
    78
    1
    Many of us don't have a "12 O'Clock position" on our receivers because we don't have traditional rotary dials for volume control. Any rules of thumb then? Mine goes from -100 DB (approx) to +13 DB.
  4. fmw Audioholic Samurai
    fmw
    Jul 5, 2007
    2,577
    489
    If you were to run 20 watts continuous in my listening room with my speakers of average sensitivity supported by a powered sub, the loud volume would drive you out of the room. it would literally hurt. 40 watts would be ridiculous. I wouldn't worry about it at all. Your speakers can take plenty.
    fmw,
  5. Seth=L Audioholic Overlord
    Seth=L
    Sep 26, 2006
    13,446
    2,014
    Don't turn it up to the point where it sounds bad, how is that for rule of thumb?:D If it sounds bad, it is bad. Don't worry much about speaker wattage ratings, as they mean next to nothing in real world applications.
  6. kappa546 Audiophyte
    kappa546
    Jan 7, 2008
    6
    0
    it's a pretty useless spec, more of a suggestion. i would listen and back off if the speakers begin to stress. besides, the speakers will not see 100w with music very often/long... sines are a different story.
Share This Page
  • CEDIA
