Hello all.
Just bought a new house, and was given the green light to build the theater I want, in our great room...As long as I can work it into "the budget", and make it pass the WAF.
The room is ~5500-6000 cubic feet, with vaulted ceilings, and carpet.
The 1st phase of my plan is to do a 85" panasonic plasma, flush mount with the drywall.
And to maximize floor space, I wanted some GOOD in-wall speakers.
My estimated budget is $8k-10k for the front 3 speakers.
And another $3-5k for the sub's.
So with that said...I have done some research, and seemed to have narrowed it down to the following...
Triad Gold/6 LCR's - $2100/ea
AtlanticTechnology - IWTS-30 LCR - $1300/ea
Deftech RLS II's - $799/ea
RBH SI-6100/R - $3150/ea
I have not listened to any of these, but am planning to prior to purchasing.
I was a musician growing up, and listen to all genre's of music.
I will be buying a new multi-channel amp, and receiver as well.
My questions are...
1. Am I missing some good in-wall speakers out there, that can properly fill a room this size?
2. Which speakers would you recommend and why?
Thank you all for your time.
Reorx
