Hello everyone, I am new to this forum and I am very excited to build a home theater system, but I am so confused after reading all of the reviews out there as to what to buy. Which of these 4 receivers below would give me the best audio for both home theater and music and the best picture quality given my set up below. Or is there another receiver in this price range (up to $3,000) that i should be considering? I was leaning towards the Pioneer, but now I'm not sure after reading this review. Here is my set up, I have everything hooked up via HDMI.
62" 1080pm DLP Mitsubishi
panasonic blu ray
kilpsh L/R speaker/center/surround
martin logan descent i sub
HD cable/DVR box
Pioneer SC 07
Denon 4308
Integra DTR 9.9
Marantz AV 8003
thanks for your help!
If I were you, I would do the following:
a) prepare a spreadsheet and list all the features that each AVR has.
b) identify which of these features are essential for you and which ones you can live without. Things to consider are 1. speakers with 6-8 ohm nominal and mid to high sensitivity which don't require a stout amp section or speakers that have low impedance lower than 6 ohms nominal and low sensitivty speakers that require a beast of an amp if its the latter case, choose the receiver that delivers the most dynamic power given the AVR are within teh same general power output capbility, +/- 10 or so watts per channel 2. latest surround sound codecs, 3. number of HDMI in and out including audio, not just an HDMI switcher, 4. video upconversion
c) if the receiver doesn't have what you absolute must have or want, eliminate it from your list.
d) For the remaining AVRs on your list, go down to the audio retailers and ask to play/use with each AVR to see ease of use. Choose the one thats easiest for you to use.
