Interesting ideas.
Maybe diffrent soundcards have relative similar analog outputs, i can't tell because i didnt experiment much.
how about using the digital out (optical/coax) from the sound card feeding an external dac (a rockna one, for example)?
do you think it would make a audible difference?
i recently found out about squeezbox.
what do you think about the receiver? (receiver optical out->external dac->amp)
thanks.
Add a Behringer DCX2496 DSP processor between the sound card's analog output and the Vincent's inputs. The DCX will give you precision control over the speaker response - to a far higher degree than a regular (worthless) equalizer control. You can, with such high precision, control the subjective 'tightness' of your subwoofer, or use subtle shelving filters to control high end sibilance. Just two examples. The DCX also has a superb GUI software that you can use to adjust it directly from your computer. Just hook it up with a serial cable. You can literally 'draw' the response you want using your mouse to push/pull the response curve using a DCX.
Read the following link where I measure a popular normal EQ vs. DCX:
http://forums.audioholics.com/forums/showthread.php?t=8930&page=3
In addition, the DCX is noiseless, assuming you set the gains correctly. It is a transparent device except for the manipulations that you intend/program. It is also a precision DSP xover system, should you ever want to add subwoofers(or supertweeters) to your desktop system.
In addition the DCX, place some 4" thick GIK Acoustics or Ready Acoustics panels behind your speakers. This will go a long way towards increasing fidelity. The GIK are cheapest. The Ready Acoustics are very 'high class' looking - but cost more.
Also, if you have the speakers sitting directly on the computer desk, or sitting on solid stands on the computer desk: put some soft cushion foam between the speaker and stand/desk. The speaker will vibrate the desk causing substantial acoustic coloration as the desk is radiating a large surface area.
Considering the price of the speakers and amplifier you are using, these extra pieces are not expensive.
-Chris
