I have the following setup
htpc--->switch---> tv (hdmi cable)
The switch is also connected to a 5.1 surround sound speaker system through a toslink cable
My motherboard is a asus prime z270a (
https://www.asus.com/ca-en/Motherboards/PRIME-Z270-A/)
I had the above outlined setup with a cheap videocard with no issues. I purchased the GeForce GTX1050Ti but cannot get the audio to play through the surround sound system. The sound will only work through the TV speakers.
I have installed the latest drivers for the video card but with no luck. When I connect the toslink cable directly from the motherboard to the surround sound, I can get surround sound however, I would like to use the switch as I have other devices.
Any advice would be appreciated.
