I went ahead and ordered the Harmony Ultimate. I debated about the lesser expensive model, but in the end just felt that the Ultimate gave me every available option of control... and most importantly, gives the best and easiest overall platform for Nancy to effectively use the system.
I just got home a bit ago to find my remote waiting for me by the front door:
First impressions are that 1) Logitech knows how to package and market stuff. I mean it looks like a very high end piece of equipment. Even the box is quite serious.
The remote itself is very nice. I have pretty big hands and this thing feels perfect. My hand just cradles the remote perfectly. Then, you got Nancy with little hands and the first thing she said is "it just fits in my hand perfectly." Design-wise, they did a great job. The charging station is equally nice. It's glossy finish looks high end and shares the same sort of non-slip treatment that remote does. I put it on a glass end table and it was pretty much stuck there. It's not something that's going to slide around willy-nilly.
The remote came with two IR blasters... I don't know if two are enough or not. I have the TV up top, and equipment inside both sides of the cabinet. I've seen where you can buy 1 into 3 and even 1 into 6 cables. This is my first time using this stuff so I know zero about it. I'm not sure if I'll be needing to buy those type of IR's because as it stands, there's two inputs and two cables. I just don't see it being able to cover my entire cabinet which is divided into 3 compartments.
This is as far as I got. I had ordered the HP USB MCE IR Adapter for the HTPC itself, but it didn't show up today... maybe tomorrow. I really have no idea how to do this part. From my initial research, I guess I just plug in the HP MCE do-dad into the USB port of the HTPC and it just sorda works. That concerns me since so far nothing has been that easy. Everything I've seen that makes sense and that I understand has been for a Windows machine, not an OpenElec box so in my mind the chances of it "just working" is slim to none.
For the Harmony setup, what I can tell so far is that I setup the HTPC as an MCE device. Apparently XBMC is fine with it being controlled as this. I don't know. We'll see.
I understand conceptually, but lack the details so far of how to do this and how that little HP box works and what it's place is in the system.
On a side note... I bought a Logitech wireless keyboard and mouse because Nancy finally tripped on the keyboard that I have plugged into the HTPC last night. So I plugged the little USB IR receiver into the HTPC and nothing. Neither the keyboard or the mouse work. If I plug my old ones in, no problem. The wireless ones aren't working at all which is what is sort of worrying me a bit about the notion that plugging in the HP receiver is just somehow going to work.
In Windows, the new hardware gets recognized and setup automatically. I don't know what, if anything, needs to be done for an OpenElec machine. More research... more reading.
