How to Choose a Flat Panel TV Wall Mount
Discussion in 'Televisions & Displays' started by admin, Nov 16, 2012.
  1. admin Audioholics Robot Staff Member
    admin
    Apr 16, 2004
    172
    1,617
    Choosing a TV wall mount can be a difficult decision because there are many different sizes, brands, and types of mounts. This guide breaks down the three most common types of mounts, full-motion/articulating, tilting, and low-profile, and then provides a few tips on what to look for in a good wall mount. Ultimately, as long as the wall mount you purchase is rated to handle your TV you shouldn’t worry about the TV falling off the wall. All of the extra features we talked about are great to have, but not always necessary. The real trick is knowing how to install the TV so it is secure and looks good. There are a lot of specialty mounts not covered in this article. The best place to find detailed information is on the manufacturer's website. If you take a look at some of the major manufacturers like Peerless, Sanus, Chief, and Omnimount you should be able to find a solution that fits your needs.
    [​IMG]
    Discuss "How to Choose a Flat Panel TV Wall Mount" here. Read the article.
Share This Page
  • CEDIA
