I am debating getting a Emotiva XPA-200 to power my mains (Aperion 6T). At present I am using a Pioneer Elite VSX-52 which is presently sending approximately 100 watts to each of my front three speakers (6T + 5C center). Since the 6T are 6ohm, I be getting around 190-200 watts out of the XPA, which is a significant jump over the AVR. Theoretically, since my receiver will only be powering one channel (center) it should be able to produce higher power, even if its not as high as the XPA. Will running MCACC on my receiver level this out? Basically, will it pull back the amplifier to balance with the center? At some point I would like to switch to a full 5.1 setup, which will change things once again.
I thought about getting a 3-channel amp to give each its own power, but XPA-3 don't come up used very often, and have more power than I probably need anyways.
Another variable is the sensitivity. The 6Ts have a 91db sensitivity, while the 5C is only 87 db. How will this impact it?
