Alright... You probably should talk to a local A/V specialist on this, but here is what I would do.
1. Run a 3/4" piece of conduit to the TV location.
2. Find a universal mount that you will actually purchase and that will determine where the conduit and wires will be run to. Since no flat panel TV actually sits DIRECTLY against the wall, you want the wires to be run to just below the mount, then you can route them into the display wherever the connectors are. Many are on the far bottom, but some are along the sides. All should be far enough behind the display to hide your cabling as it wraps around.
3. You absolutely should run: 1 component video cable, 1 s-video cable, and 1 composite video cable. All 6 of these cables can actually be RG-6 coaxial cable and then converted to RCA connectors on the end. Run them NOW as you absolutely, positively KNOW you will eventually need them - or at least component and composite.
4. If you want to use DVI or HDMI, then find a cable long enough NOW - run it now.
5. Get POWER to the LCD location, just under the mount, a few inches away from where the cables are going to be run.
6. If you are going to use surround sound in the room, then run speaker wire - NOW.
7. If you have an unfinished basement below the room, then that is where you should run the cables to - then back up a wall in the room where the equipment is actually going to live. You really should try to figure out where the equipment is going to live... once again - now.
8. If you absolutely don't want to run the wires now - then I would only use a 2" piece of conduit to handle all possibilities.
9. Oh, if you don't plan on using a surround setup, but want to use the speakers inside the LCD/plasma... I would change my mind. You will have to have an FPD will enough inputs to handle everything you want to hook up and you will have to have enough video AND audio feeds for all of those products. Financially speaking, an A/V receiver (surround or stereo) is a good purchase for your room, even if you don't use the amplifier inside the receiver.
What is a sky box?
