1) Would like to stay under about 2k if possible, but will go higher for the right speakers
2) Receiver is 6.1 so i would like all 6 replaced eventually
3) Yes i've done some auditioning and comparing. Spent some time really listening to the differences in frequency response, boxiness of the sound, strain of the sound, etc. So far im leaning towards a pair of Klipsch bookshelf speakers (forgot to write down model #) at Ultimate Electronics for around $450
I also did some shopping via craigslist.com and found some good prices on older speakers (manufactured around 89 i think). Has speaker technology progressed enough since then that i would be better off buying new? Or, assuming these sound good still, would it be a better move to get the older ones? The Speakers in question are KG2 WO's
Another thing: My receiver is rated at 8 Ohms. In all of your experiences, is it best to match the Ohms of the speaker to that of the receiver? From my understanding the only thing i am doing by using my 4 Ohm HTIB speakers is forcing my receiver to work a bit harder. Is that correct? Is the fact that the KG2's mentioned above have a 4 Ohm rating and also a 65 Watt max continuous power handling (325 max) going to cause problems with my receiver (110 watts per channel) So my speakers would only be "asking" for 65 Watts, but in order to compensate for the difference in impedance my receiver would likely be "sending" more than this. Is that correct?
Thanks again for all the help.
