Gooday Everyone!
So I am very fresh into this, and was looking for some good advice for a rather basic setup to use with my home computer.
The plan is to have a setup in my bedroom with a speaker tower or bookshelf on either side of the bed, and hopefully as few wires as possible connecting to my laptop(MacBook Pro) which I typically use on the bed or over on a desk not far from it.
I was looking at doing this mostly used, with likely the only piece of new equipment being the DAC(unless I can find one used as well) Looking to put down roughly 1000-1250 on this setup as it is mostly my first jump into this. So I wanna learn with something on the cheaper end before I build something more advanced.
The thought was to pick up a pair of used B&W DM303, and possibly a Arcam rDAC, however beyond that I haven't really figured much out. If you could offer me some advice as far as better options, good places to do some research or even a breakdown of a setup that would work within my price range, It would be very much appreciated.
Thank you in advance.
