Hi there,
I am looking for an answer to a simple question:
If I have a speaker that goes down to 40Hz and a sub, do I need a high pass for the speakers (such that they only get 40Hz + signal)?
I've heard that sending the entire signal to a speaker that can't go down to 20 Hz introduces distortion. How much of this is true?
Thanks a bunch for your time.
I've been led to believe that ideally you will want a high pass for the speaker, unless you are assured that they will not be replicating the same bass frequencies, for then you suffer unpredictable amplitude and phase interactions.
THAT SAID, it seems that most people, myself included, use compromised bass mgmt most of the time. People skin this cat in many different ways, including using multiple subs all over the place (which has the same "issue" of duplicate bass).
I've been led to believe something like the discontinued Outlaw ICBM could be desired in a situation like yours. Or perhaps the Behringer DCX (more difficult to understand).
While I'm trying to speak in terms of what I think is supposed* to be the ideal, I also have the impression that for people like you and me, there is no substitute for experimentation. If it sounds good, it sounds good, and there's probably a reason for that. If the bass is bloated, or is masking the other audio, obviously that's not good.
I'd just keep playing around with the REL's low pass, phase, gain, etc, and just as importantly, the position of the sub itself.
