Hey everybody. I am extremely excited about putting together my first home theater setup! We just recently moved into a new house and for the first time, we have the space to do it! I was also lucky enough to have been given some free speakers to get me started! I have been doing some research and have given it much thought. I would really appreciate any opinions or advice on setting this stuff up, but here is my plan so far:
This is the space that we have to work with. It is a mostly finished basement, with an existing entertainment center. The area that the couch and system will go is about 15' long from the bar area to the front of the entertainment center, and about 13' from the wall to where the right side speakers are mounted.
There are a few downsides to the basement area. Firstly, it is not a huge area to work with but it's big enough to be cozy. Secondly, there is no carpeting. We have kids that make a big mess, so we think we will just get a large piece of bound carpeting for the TV area to warm it up and to absorb some sound. We are shopping now for a sectional to go along the wall on the left side, and L out parallel to the tv position. Also, the toys, the litter box and the kitty apartment will be GONE. This area is doubling as a play area until we get it together lol.
Ok, on to the the TV! Originally I thought I would be getting a 55" ST50 to fill that big empty space, due to the stellar reviews but After looking at a lot of TV's at Best Buy I think I am just a fan of the LED picture just a little bit more. The TV will be used mostly for movie night and for gaming on XBOX360. I believe I will be getting a Samsung UN55ES7500. It just looks awesome, and I am a fan of the camera on top because we skype a lot. I mostly love the thin bezel it has. I plan on leaving the speakers on the entertainment center in the position that they are in above. If I mount the LED on the back of the entertainment center so that it hovers above the shelf instead of sitting on it...I will have JUST enough room to leave that center speaker at rest where it is, and the TV will fill the rest of the space nicely.
As I mentioned, I was lucky enough to get some free speakers! My old man gave me 3 Bowers & Wilkins VM1's for my fronts and center channel. He has had them for quite a while and I always loved them. Placement will be as shown above. He also gave me a Klipsch RW-10 sub. I think these are a great come-up for free!
The sub is going to be placed at the end of the couch, about 2 feet from the bottom left cabinet, aimed out accross the entertainment center. The 4 black Samsung speakers that are mounted up near the ceiling are going to be gone. I will be putting block off plates up where the fronts were located. I will be installing a pair of Bowers & Wilkins M-1 speakers for my rears. I will be keeping the location of the rears up high where the current ones are located. Wires are already run through the drywall, and that position is as close as I'm going to get to optimal.
I picked up last years Denon 2112ci receiver for a pretty good deal, and it should arrive in the next few days. I wanted something with airplay, and MultiEQ XT. I also wanted something that I could expand to a 7.1 system in the future with 2 more speakers. It also seemed like great bang for the buck and I'm all about that. Now for the bad news. I can't fit this puppy anywhere on the shelves of the entertainment center. Whoever built it did so without a great worry for the size of A/V components. The only place it will fit in in the bottom cupboard, just to the left of the center cupboard above. This is NOT a good spot, but it's all I've got. I put an older Denon receiver in there and snapped a pic for scale. The 2112 will be roughly the same dimensions. It is a snug fit.
My plan is to nestle the 2112 in this cabinet, and set up an IR extender and a cooling fan. What do you guys think? I am looking at a dual 120mm fan setup that I can install inside the cabinet cupboard. I would install it so that the hot air from the receiver would be blown out into the center cabinet with the speaker grill material on the front.
This is the cooling fan setup that I was looking at:
Coolerguys PRO-Metal Dual 120mm Deluxe Cabinet Cooling Kit with built-in LED Controller CABCOOL 1202-Deluxe-M
My last step was going to be to install a few acoustic panels on the walls to the left and right of the viewing area.
Anyway, that is the plan. What do you guys think about component choices? The space? Any tips or suggestions? Thanks you guys
