<font color='#000000'>What should the crossover be set at (Music) I was am using B&W 604s2 & and a 12" Sub KG-5230 from Speaker City USA. I had the STR-DA5000ES crossed over at 80Hz and the mains set to large and the sub set at 75Hz, sounded great at normal to medium volume but not too good when dialed in to 0db to +3db.
I then Crossed over the 5000ES to 40Hz set the mains to small and changed the sub to 60Hz. Could play loud 0db to +4.5db for a long time an hour or so with Jazz Rap & rock type music and sounded loud and clear bass was much better. (bass response wasn’t as good as my 7ES though)
At medium vol like -20db it was missing the punch in the bass so I had to turn up the sub a little. What is the suggested happy medium, or the recommended X-over settings and speaker set-up (Large or Small)??? The manual suggests Large for towers but I've read, more than once, to set to small even if they are towers and using a powered sub.
By the way, this amp runs way cool; I mean way cooool, compared to my 7ES. In the cabined I have the 7ES gets so hot if you lay your for arm on it, (say you are reaching over it to un plug something, you will fry your arm, in two seconds. not the case w/the 5000ES it is so cool, not a bother at all. Did anyone else notice that?</font>
