Posting in the speakers forum since it seemed more appropriate than the Rcvr. forum
Hi,
First off, what excellent forums you have here @ Audioholics!
I had a really old (~ 11 years old!) Sony Dolby Pro Logic rcvr. which I just replaced with a Denon 3805 based on the feedback/reviews in the rcvr. forum.
Unfortunately, I'm still stuck my old Bose AM7 speaker set which I was using with the old Sony rcvr. They sound a little bit better paired with the new Denon - but - basically they still suck.
I need your help/suggestion on the following (as I'm basically clueless in the HT dept
- What are your thoughts on pairing the Denon 3805 with the Mirage OMNISAT v2 FS and CC speakers? If not, what are some good options (mainly for watching movies) if I have a budget of $1500.
- Can I use the old Bose speakers as surrounds?
Thanks in advance.
