Hi Y'all,
I have a decent size living room that I would like to have a disguised Home Theater in. I'm planning to install an automated projector lift, and motorized screen. The room light is controllable since I have shutters, the room is 38 feet x 15 feet and there is no dry wall, only sheet rock ceiling, therefor I'm obligated to use in-ceiling speakers all the way, the room is rectangular and I was planing to put the screen at the end of the left 15 feet wall, but have my doubts for the speakers and receiver. And my questions are:
1. For the size of the room, what will be a suitable wattage for the receiver?
2. 5.1 or 7.1?
3. Should I use angled in ceilings for LRC?
4. How do you recommend speaker placement, distances apart from the screen? LCR distance apart (15 feet wall)
5. Do you think i could put a 106' screen?
6.How can I post the room's blueprint?
Thanking you in advance,
qvilorio
