Your sale may go smoother if you explain that the sub your selling is the Velodyne VRP-1000.
Specs,
Amplifier: Monolithic MOS Class A/B:115 watts RMS 170 watts peak
Woofer: 10" (24.5 cm) forward firing (8.2" piston diameter)
Magnet Structure: 2.5 lbs (1.1 kg)
Frequency Response: 35-140 Hz +/- 3 dB
Voice Coil: 2" copper-wound
Cone: Coated Fiber
Speaker-Level Pass-Through: Full range
Low Pass Crossover: 50 Hz - 200 Hz
Cabinet Design: Acoustically neutral, rear ported
Outputs: Left and right speaker level pass-through
Inputs: RCA Line Level, LFE and Speaker Level inputs
Phase: 0° or 180°
Auto On/Off: Yes
Removable Grill: Yes
Video Sheilding: Yes
LED Power Indicator: Yes
Weight: 37Lbs (Approx)
Cabinet (H/W/D) Black Ash Wood-grain with High Gloss Black accent: 15" x 12" x 16" 38.1cm x 30.5cm x 40.6cm
There, now all you need is a picture.
SheepStar
