Frames for acoutic panels
Discussion in 'Room Acoustics, System Layout & Setup' started by pjoseph, Dec 12, 2012.
  1. pjoseph Full Audioholic
    pjoseph
    Sep 28, 2007
    299
    22
    I am looking to purchase some frames only, I checked out two sites online, and i notice that the dimensions do not take into consideration the thickness of the frame material
    for example it list Outside dimensions of
    48" X 24" X 2"
    Which is the same size as the material that is suppose to fit inside, meaning each one would have to be trimmed down to fit correctly.
    Does anyone know of a good place to get ones that has the above dimensions but for the inside not outside ?
    thanks'
  2. Shrader Audioholic
    Shrader
    Apr 18, 2012
    130
    31
    Northern WI
    Just make some up out of 1X pine, I did six panels 24x48x4" in an hour and it costs less than 20$
    • Like Like x 1
  3. nibhaz Audioholic Chief
    nibhaz
    May 24, 2004
    950
    414
    Lafayette, IN
    I assure you these are design to hold the material like you are wanting to do.
    The only caveat I have is the company may or my not be circling drain or at least having supply issues because they no longer sale their ready bags by themselves and they have been hard to come by for awhile now. This is pure speculation from a casual observer but after getting burned myself this year by an internet supplier I'm a little more weary about such things:rolleyes:
    But as has already been suggested DIY pine frames are cheap, easy and proably the best route.
  4. Jeff R. Audioholic Chief
    Jeff R.
    Dec 3, 2008
    900
    108
    Cape Cod, MA
    I used 2 x 3 pine boards from the hardware store....very quick and easy to do. I just screwed them together and then put the foam in the fram and stapled my fabric over the edges the wood on the back side.
Share This Page
  • CEDIA
