Enter to Win: Wireless Subwoofer from Aperion Audio!
Status
Not open for further replies.
tsjdesign
1. How important is it to you to match the look of the surround sound speakers with the front speakers in a 5.1 or 7.1 system?
Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
2. Currently, if you have surround speakers where are they located? If don’t have surrounds, why not?
Wall mounted (Concealed wires)
3. If there was a high quality wireless surround sound speaker available would you consider it for a home theater system?
Yes, a wireless surround speaker would be great.
4. Wireless speakers have the amplifiers built in and so they need to be plugged into the wall for power. Would this limit you from considering wireless surrounds?
No, I have outlets all over the place.
5. When you buy audio electronics, some products use an inline power adapter (“Power Brick”/”Wall Wart”). If you are considering a wireless speaker for surrounds and where you’d place them, which would you prefer? (Please choose one)
Inline Power adapter such as Power Brick or Wall Wart with thin DC
6. If you were looking for a surround speaker to match your existing front speakers but had to buy another brand, what features would be the most important to you?
The sound
team_finga
Contest Questions
Not important. Sound is what matters.
Wall mounted (Concealed wires) -- Actually, ceiling mounted
Other (Please explain) It would depend on the placement, but I might be able to get power to wireless surrounds.
Doesn’t matter
The sound
dweazil
4. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
1. Wall mounted (Concealed wires)
1. Yes, a wireless surround speaker would be great.
1. No, I have outlets all over the place.
3. Doesn’t matter
2. The size of the speaker
droht
droht
in ceing
Other - would be a hassle but not the end of the world
Internal Power Supply, so it has an AC Power cord only.
Keeps everything looking more clean
The sound
douglaswweb
Contest
d. Somewhat important. I would like to get a matching set, but what works best for my theater/space is of most importance.
d. Bookshelf or end tables
a. Yes, a wireless surround speaker would be great.
c. Yes, I want a clean custom installed look, the power cords would be a deal
a. Internal Power Supply, so it has an AC Power cord only.
a. Shape/design of the speaker
dri3835
contest entry
Quite important, since this system is in my living room I want it to look good as well as sound good
Tall stands
Yes that would be great, but again you need wire for power...
Possibly, because you need an outlet high enough otherwise you need the power cable to be visible
Doesn't matter as long as I can have no visible wires
The sound and looks should be consistent with the fronts as much as possible
Nossus
Nossus
Yes, I have a difficult room that doesn’t allow me to conceal the wires.
The elusive WAF is a difficult monster to champion here, so there is always a compromise between sound and aesthetics.
Porkys
Other (Please explain) no i am building a new cinema room so i could always add wall plugs where speakers are gone be anyways
doesnt matter which as long as it sounds good
The sound
davidthi
Here's my answers to the Contest Questions:
I don’t have surround speakers because still researching a/v receivers.
malibujeff
Yes, I want a clean custom installed look, the power cords would be a deal breaker.
The sound
rana_gman
- Somewhat important. I would like to get a matching set, but what works
- Bookshelf or end tables
- Yes, a wireless surround speaker would be great.
- No, I have outlets all over the place.
- Internal Power Supply, so it has an AC Power cord only.
- The sound
bciocco
2. Not important. My surround speakers are on the other side of the room so it doesn’t really matter if they all match or not.
4. Bookshelf or end tables
2. Inline Power adapter such as Power Brick or Wall Wart with thin DC power cord going to the speaker.
3. The finish/color of the speaker
CoolBob
Contest Questions:
No, I don’t trust wireless quality yet.
The sound
mmljarc
The sound
Mike JL
Contest Questions:
Other - I have towers as surrounds. The wires are run in-wall.
Doesn’t matter
Please explain - the speakers aren't wireless if they have a power cord. Might as well run speaker wire.
The finish/color of the speaker - there is a WAF component to the selection.
V
vagirl
Speaker Stands
Doesn’t matter
The sound
O
ohio
The sound
(both)
dad311
1. Not important. Sound is what matters.
3. Speaker Stands
2. No, wireless surrounds are the only solution for my room because I
1. Internal Power Supply, so it has an AC Power cord only.
4. The sound
jairus
The sound
Status
