So, I know the heading doesn't make a lot of sense, your thinking where's this knucklehead going with this?
Please bear with me.
I would like to get all my CDs saved in Flac form for preservation, organization and playback. I have a Home system with Marantz 5011 AV receiver used as kind of a "preamp" = Pre out going to Rogue Audio Sphinx and two Martin Logan Motion 15s. Eventually I will use the Sphinx to feed 2 Spatial M3 Turbos and use the Logan Martins and one Cambridge Soundworks speaker for Surround and center channel. Turntable, TV, and digital files connected to the 5011 as a preamp. Is this a good way these components should be set up for 5 channel surround and then the best sound I can get in just stereo?
Second system is at the office with an older Yamaha M4 and Mcintosh 5100 with some older B&W monitor speakers. Setting this up for base system for playing digital Audio and messing around with vintage components.
I'd would like to use somewhat portable storage for these and other systems while keeping things high quality.
Option 1: Buy a Emotiva Stealth DC1 ($500) which will allow very good sound for either system and buy a laptop with external drive ($500?) for storing all my CDs and future purchases on FLAC.
DC1 is a much better DAC component
DC1 seems more flexible to use with different systems
Less expensive than option 2
Could have limitations on storage size over time
Less portable (more pieces)
Laptops life expectancy is limited
Possible laptop crashing
Option 2: Buy a single Bluesound Vault 2 ($1,200) and rip, store and play back using Bluesound App.
Pros:
All in one unit, unplug and use in the office, on the boat, friends house etc...
TI Burr Brown 32-bit/384kHz DAC (this seems like a good DAC, will I hear the difference?)
Might be more secure storage than laptop
2 TB of storage
Cons:
App could be clunky
Reports of older Vault 1 not reading CDs well
I have found no really great reviews
Sorry for the long question, but I figure you people are detail oriented
