Well, to start this off I was one of the March 2006 Audioholics winners of a 7.5 meter "DVI Gear" Super High Resolution (SHR) HDMI cable.
I received the cable today, April 12th. THAT'S FREAKIN' FAST SHIPPING FOR SOMETHING I WON
The first thing you notice is the shear diameter of the cable.
IT'S HUGE Must be about 1/2" across (12mm).
The cable states right on it that it is 22AWG, triple shielded, AWM20276 and UL type CL2. That's a heavy duty cable! The connectors are gold plated and the plugs are heavy bonded (molded), not loosely attached.
According to DVI Gear's web site, the cable is rated for 1080p and PC resolutions up to 1920x1200 / 60Hz. Also, single link bit rates up to 1.65 Gbit/sec. In other words, ready for the future!
My next project will be to pull all my cables out of the 2" conduit running to the projector to pull this BEAST through (wish I would have run a 2 1/2" conduit
). Let's just say that conduit is PACKED!!! RGB component, HDMI, composite and S-video. The RGB component cable is an Anaconda, over 3/4" diameter with BNC ends. Needless to say, everything comes out before anything goes in. Granted, the nice thing about DVI Gear's cable is that the UL CL2 rating would allow me to run it without conduit if I wanted.
All I can say is, if you guys want a
QUALITY cable that will last a lifetime and is designed for the future,
THIS IS THE ONE. Look no further.
Of course, you know this means I'm forced to spend more money now
Now I can get that new HDMI upconverting DVD player I've been wanting. And that means I absolutely
HAVE to buy an HDMI switcher..............and you all know where I'm going to buy that................
DVI Gear, of course! (Clint, can you hide that from loserwife?
NOTE TO DVI Gear: You should show a picture of the cable with a penny or something next to it for scale. And show the markings on the cable. Let people know that these thing are Mofo cables that shouldn't be taken lightly. Oh, and you guys rock!
