I currently have an SVS PB-12DSP unit that I purchased in December. I'm using it in my living room setup (21 x 11.5 x 8ft) that has a door sized opening that goes to my kitchen. I want to get at least one more sub in this setup to even out the bass response in my room. I'm not unhappy with the way my SVS performs and my initial intention was to get another one and call it good.
But, after some research I figure I can build two subs with similar performance for less than a new SVS and for just a little bit more I can build four and either sell my SVS or find another room for it.
I have two Infinity Kappa 10.1's that were previously in my car that I can build ported boxes for and get either two Kappa 120.9's to accompany them or just get four Kappa's 120.9's and skip using the 10.1's. I would use the Simple 12" Infinity Kappa VQ MidQ Plans that are stickied in this section for the 120.9's and I found some other plans for a box for my 10.1's that is very similar in build and output as the Simple 12" Infinity Kappa VQ MidQ Plans.
I would get a Behringer EP4000 to power all of these subs and a Behringer DCX2496 to control them.
So would four subs be overkill for my room? If so, would you just use the 10.1's or would you go with the 120.9's? If not would you use both the 10.1's and get two 120.9's or would you just get for four 120.9's? Any and all advice is much appreciated.
