Hi Guys
I am new here and that's my very first DIY project, I got lots of questions but could solve most of them researching.. the system I want to build is the following:
1 x Sub: 50W
2 x Midbass: 30W
2 x Tweeter: 15W
All of them is (4Ohm), and I am struggling how to wire them. I thought to use a 2.1 AMP - 100W+2*50W, so I can wire the Sub on the mono 100W, and each R and L 50W wiring Midbass+Tweeter in parallel.
I am not sure on what is going to happen basically with the mid+tweeter in parallel (plus crossovers)... do you guys see any problem on this configuration, as theis wattage is different? Should I use any resistor to balance or to sum up some impedance to avoid problems?
I really don know what I need to do here, need somebody to tell me that I am going in a good/bad way and what I need to do in order this system is good.
Thank you very much!
Rene
