Product Specifications
Amplifier Section
Power Output -
Front L/R 140 W + 140 W (8 ohms, 20 Hz–20 kHz,
0.05%, 2 channels driven, FTC)
160 W + 160 W (8 ohms, 1 kHz, 0.7%,
170 W + 170 W (6 ohms, 1 kHz, 0.1%,
Center 140 W + 140 W (8 ohms, 20 Hz–20 kHz,
Surround L/R 140 W + 140 W (8 ohms, 20 Hz–20 kHz,
Surround Back L/R 140 W + 140 W (8 ohms, 20 Hz–20 kHz,
Dynamic Power 320 W (3 ohms, 1 ch)
270 W (4 ohms, 1 ch)
160 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) 0.05% (Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phono MM)
Output Level and Impedance 200 mV/470 ohms (Rec out)
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control ±10 dB, 20 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 110 dB (Line, IHF-A)
Speaker Impedance 4 ohms–16 ohms or 6 ohms–16 ohms
Video Section
Input Sensitivity/Output Level and Impedance -
Video 1 Vp-p/75 ohms (Component and S-Video Y)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
0.28 Vp-p/75 ohms (S-Video C)
1 Vp-p/75 ohms (Composite)
Component Video Frequency Response 5 Hz–100 MHz (-3 dB)
Tuner Section
Tuning Frequency Range -
FM 87.5 MHz–107.9 MHz
AM 530 kHz–1,710 kHz
FM/AM Preset Memory 40 stations
General
Power Supply AC 120 V, 60 Hz
Power Consumption 9.5 A
Dimensions (W x H x D) 17 1/8" x 7 5/8" x 18 1/16"
(435 x 194 x 458.5 mm)
Weight 50.9 lbs. (23.1 kg)
875
Amplifier Section
Power Output -
Video Section
Tuner Section
General
